Home > Forums > CFX
residuals
Old   July 2, 2001, 02:54
Default residuals
icmyn
Nowadays, I am using CFX4.3 to model gas-solid two phase flow. It is a unsteady problem, so the residuals should oscillate. But the residuals of monitor point in my simulation become a flat line with residual steps increasing.It puzzled me very much. Does anyone know the problem? Thanks in advance.
Old   July 2, 2001, 16:40
Default Re: residuals
P.Fonteijn
Do you perform steady or unsteady calculations?
Old   July 2, 2001, 21:54
icmyn
i perform a unsteady calculation.
Old   July 4, 2001, 15:55
P.Fonteijn
Your residuals might look stationary but is your solution stationary? It also depends on where you monitoring point is located. If it is located near an inlet it might show stationary behaviour.
P. Fonteijn
Old   July 11, 2001, 03:58
John C. Chien
(1). You may want to display the results at two iteration numbers in terms of the contour plots. (2). By comparing the contour plots at two different time steps, you can easily see the change in flow field and the specific areas or locations. (3). Area near the inlet normally converges faster because it is affected by the inlet conditions. (4). On the other hand, the exit area is always slow in convergence. Loca region with flow separation is also slow in convergence. So, the contour plots will be very useful to provide these information.
Thread Tools
Trackbacks are On
Tutorial of how to plot residuals ! wolle1982 OpenFOAM Running, Solving & CFD 127 December 1, 2015 19:45
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 04:59
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 18:10
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
residuals Karl CFX 2 June 24, 2003 23:13
