-   -   Help! (http://www.cfd-online.com/Forums/cfx/18574-help.html)
pengsh July 11, 2001 09:54
Help!
I want to simulate the liquid steel flow in a Ladle stirred by Ar injeted from the bottem. But the result is wrong! The below is my fc file:
>> CFX4
#CALC
RHOL = 1000.; /* Properties */
RHOG = 1.28;
VISL = 1.0E-3;
VISG = 1.0E-5;
SRFTEN = 0.025;
BUBDIA = 2.0E-3;
U1 = 0.0; /* Inlet */
U2 = 0.0;
V1 = 0.0;
V2 = 0.0;
W1 = 0.0;
W2 = 0.0;
VF2 = 0.01;
VF1 = 1.0-VF2;
DIAM = 0.1;
#ENDCALC
>> OPTIONS
NUMBER OF PHASES 2
BUOYANT FLOW
TURBULENT FLOW
END
>> MODEL DATA
>> PHYSICAL PROPERTIES
>> BUOYANCY PARAMETERS
GRAVITY VECTOR 0.0 -9.8 0.
BUOYANCY REFERENCE DENSITY #RHOG
END
>> FLUID PARAMETERS
PHASE NAME 'PHASE1'
VISCOSITY #VISL
DENSITY #RHOL
END
>> FLUID PARAMETERS
PHASE NAME 'PHASE2'
VISCOSITY #VISG
DENSITY #RHOG
END
>> TURBULENCE PARAMETERS
>> TURBULENCE MODEL
PHASE NAME 'PHASE1'
TURBULENCE MODEL 'K-EPSILON'
PARTICLE INDUCED TURBULENCE 'NONE'
END
>> TURBULENCE MODEL
PHASE NAME 'PHASE2'
END
>> TURBULENCE CONSTANTS
CMUPI 0.6
>> MULTIPHASE PARAMETERS
>> PHASE DESCRIPTION
PHASE NAME 'PHASE1'
LIQUID
CONTINUOUS
END
>> PHASE DESCRIPTION
PHASE NAME 'PHASE2'
GAS
DISPERSE
MEAN DIAMETER #BUBDIA
END
>> MULTIPHASE MODELS
>> MOMENTUM
INTER PHASE TRANSFER
IPSAC
END
>> INTER PHASE TRANSFER MODELS
>>MOMENTUM
FIRST PHASE NAME 'PHASE1'
SECOND PHASE NAME 'PHASE2'
SURFACE TENSION COEFFICIENT #SRFTEN
>>PARTICLE DRAG MODEL
FLOW REGIME 'DISTORTED'
END
>>NON DRAG FORCES
LIFT FORCE
LIFT COEFFICIENT 0.03
WALL LUBRICATION FORCE
LUBRICATION COEFFICIENTS -0.01 0.05
TURBULENT DISPERSION FORCE
DISPERSION COEFFICIENT 0.1
END
>> AMBIENT VARIABLES
PHASE NAME 'PHASE1'
U VELOCITY #U1
V VELOCITY #V1
W VELOCITY #W1
VOLUME FRACTION #VF1
END
>> AMBIENT VARIABLES
PHASE NAME 'PHASE2'
U VELOCITY 0.0
V VELOCITY 0.0
W VELOCITY 0.0
VOLUME FRACTION #VF2
END
>> SOLVER DATA
>> PROGRAM CONTROL
MAXIMUM NUMBER OF ITERATIONS 500
MASS SOURCE TOLERANCE 1.0E-10
END
>> EQUATION SOLVERS
PRESSURE 'AMG'
END
>> UNDER RELAXATION FACTORS
U VELOCITY 6.5000E-01
V VELOCITY 6.5000E-01
W VELOCITY 6.5000E-01
PRESSURE 1.0000E+00
VOLUME FRACTION 0.6000E+00
VISCOSITY 1.0000E+00
K 3.0000E-01
EPSILON 3.0000E-01
>> FALSE TIMESTEPS
U VELOCITY 1.0E-1
V VELOCITY 1.0E-1
W VELOCITY 1.0E-1
END
>> MODEL BOUNDARY CONDITIONS
>> INLET BOUNDARIES
PATCH NAME 'INLET'
PHASE NAME 'PHASE1'
U VELOCITY #U1
V VELOCITY #V1
>> INLET BOUNDARIES
PATCH NAME 'INLET'
PHASE NAME 'PHASE2'
NORMAL VELOCITY 23.1
>> WALL BOUNDARIES
PATCH NAME 'WALLB'
PHASE NAME 'PHASE1'
TAUX 0.0
TAUY 0.0
END
>> WALL BOUNDARIES
PATCH NAME 'WALLOUT'
PHASE NAME 'PHASE2'
TAUX 0.0
TAUY 0.0
END
:> STOP
What's the wrong?
Gert-Jan van der Gulik July 11, 2001 16:37
Re: Help!
Could you be more specific? Do you have a preliminary error or is the result unphysical?
At least replace :>STOP with >>STOP
Regs, Gert-Jan
pengsh July 12, 2001 02:43
Re: Help!
Oh, sorry! the ":" was a mistake made by me when post this message.
My project is a Ladle(a cylinder) in which Liquid Steel is. AIR(or Ar)is injetted into the ladle from a little inlet on the bottom(the Velocity is about 20~30 m/s). And the top of the ladle(above liquid steel) is also air(quiescent).
Regs,
