Home > Forums > CFX
Saving plots.
Old   August 27, 2001, 09:55
Default Saving plots.
J. Keays
Could anyone tel me how I can save a post-processing plot to file as a bmp, tiff or any other file format. I can plot say a contour plot of pressure, but I can't figure out how to save it to file.
kind regards,
John.
Old   August 27, 2001, 13:15
Default Re: Saving plots.
cfd guy
John,
If you're using Analyse (CFX 4.3 - 4.4) you must go to file menu and then Print Image File, there you can choose your desired format. But if you're using Visualize (CFX-5), you must do a similar procedure. However, if you're using CFX-View, the only choice you have is to export a Postscript file (.ps)
Regards,
cfd guy
Old   August 27, 2001, 13:16
J. Keays
Thank you. I have figured it out. Actually,. I have another question. How do I create points on a plane whose pressure or velocity values I can actual read? IN other words, I want to get the pressure and velocity at points on a plane. Thanks again!
Old   August 29, 2001, 02:51
Ragnhild Halden
One way of doing this is to create an XY plot in Analyse. There is even an option to save this plot to file, then you can open this file in f.ex Excel, and view all the values you want!
Thread Tools
Trackbacks are On
Cp Plots Saj STAR-CCM+ 1 October 12, 2010 09:50
vector plots and contour plots do not match swati_mohanty FLUENT 1 August 26, 2010 05:53
Saving residual/monitor point plots siw CFX 5 August 5, 2010 04:10
Smooth plots of external data samu CD-adapco 2 May 21, 2006 13:08
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
