[Sponsors] | |||||
Hi All, I am interested in simulating flow in a centrigufal compressor using CFX-TASCFLOW. Following are the conditions, what I applied for initial run. 1. rfr with specified omega 2. Walls stationary with relative frame of reference 3. Inlet with total pressure 4. Outlet with mass flow specified. I started with incompressible , turbulent flow, air is the fluid. I am not getting rise in pressure from inlet to outlet. What could be the casues ?
Thanks for your time. Veebs |
Is your guess appropriate? Did it converge? What interface is it frozen or? What time step?
Veebs,
How have you defined the inlet direction components? Robin |
Hi Erich /Robin, Thanks for your time. simulation aimed for only the impeller.So have one doimain defined as rotating. Solution is converged. But it shows decrease in pressure / total pressure from inlet to outlet. (no pressure rise). At the inlet, total pressure normal to the surface is defined. Thanks again Veebs
Hi Veebs,
Defining the direction vector to be normal to the inlet face results in a vector which is normal to the face relative to the rotating frame, thus resulting in a high degree of pre-whirl and corresponding drop in pressure rise. Re-define your inlet velocity components to be axial and you will get the pressure rise you expect. Best regards, Robin |
What about the direction of rotation? If you rotate it in wrong direction, you could get this problem. Give it a try.
Drona |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 8 | July 3, 2011 20:58 |
| question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
| Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
| G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
