making a rotating frame of Reference
Old   September 24, 2001, 02:43
Default making a rotating frame of Reference
VEEBS
Hi All, I am interested in simulating flow in a centrigufal compressor using CFX-TASCFLOW. Following are the conditions, what I applied for initial run. 1. rfr with specified omega 2. Walls stationary with relative frame of reference 3. Inlet with total pressure 4. Outlet with mass flow specified. I started with incompressible , turbulent flow, air is the fluid. I am not getting rise in pressure from inlet to outlet. What could be the casues ?
Thanks for your time. Veebs
Old   September 24, 2001, 10:09
Default Re: making a rotating frame of Reference
Erich
Is your guess appropriate? Did it converge? What interface is it frozen or? What time step?
Old   September 24, 2001, 17:59
Robin Steed
Veebs,
How have you defined the inlet direction components?
Robin
Old   September 25, 2001, 00:09
VEEBS
Hi Erich /Robin, Thanks for your time. simulation aimed for only the impeller.So have one doimain defined as rotating. Solution is converged. But it shows decrease in pressure / total pressure from inlet to outlet. (no pressure rise). At the inlet, total pressure normal to the surface is defined. Thanks again Veebs
Old   September 25, 2001, 00:18
Robin Steed
Hi Veebs,
Defining the direction vector to be normal to the inlet face results in a vector which is normal to the face relative to the rotating frame, thus resulting in a high degree of pre-whirl and corresponding drop in pressure rise.
Re-define your inlet velocity components to be axial and you will get the pressure rise you expect.
Best regards, Robin
Old   September 25, 2001, 06:09
Drona
What about the direction of rotation? If you rotate it in wrong direction, you could get this problem. Give it a try.
Drona
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
