October 9, 2001, 02:16 |
Wall function treatment
Hi All,
What is the use of fixed_wall_distance_model = t, function in tascflow. It is given it will work for y+ less than 100. Does that mean even if we have y+ less than 20 ( lower limit for standard log law wall function), calculation will be accurate ? Thanks for your time Veera |
October 9, 2001, 23:19 |
Re: Wall function treatment
Hi Veera,
With k-epsilon and a standard wall treatment, y+ values must be maintained between 20 and 100. If y+ is too large, the boundary layer will not be sufficiently resolved; if y+ is too small, the wall function approximation will be inaccurate. The latter becomes problematic if one wishes to perform grid refinement studies, because as more nodes are added and y+ drops too low, the results will get worse. The fixed_wall_distance_model flag selects the scalable wall function model in CFX-TASCflow (also available in CFX-5). This formulation will not be adversely affected by small y+ values, but still requires that y+ be below 100. Thus the scalable wall function allows grids to be refined without violating any wall function assumptions. The theory documentation provides detailed information about these and other turbulence models available. Regards, Robin |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Wall function formulation in CFX and Fluent | gravis | ANSYS | 0 | May 4, 2010 11:03 |
Face merging, patch definition, wall function | Sandu69 | OpenFOAM | 2 | March 24, 2010 11:48 |
LES wall treatment | Valerio | FLUENT | 0 | April 26, 2008 07:12 |
RSM with enhanced wall treatment | zwdi | FLUENT | 1 | April 24, 2005 20:36 |
