flow in a vibrating pipe
Old   October 30, 2001, 08:35
Default flow in a vibrating pipe
xu
I am using CFX4 to model water flow in a vibrating pipe in order to couple with ANSYS result for fluid-solid interaction.
Here I want to consult for the question related to CFX 4 as follows:
Do I need to cut the period into several time steps and input the pipe shape every step to run static flow model? Or CFX with its routine can handle the flow of the whole cycle shape change in one program related to moving boundary to run transient flow due to shape deformation?
If it is the later choice, what I should to check besides USRSRC and a sliding grid?
Thanks very much and best regard
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
HTC in Pipe flow subsemitonium CFX 6 May 6, 2013 22:00
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
