-   -   Mass residuals (http://www.cfd-online.com/Forums/cfx/18691-mass-residuals.html)
Hamsdi October 25, 2001 05:04
Mass residuals
Hello, I want to check the mass residuals before choosing a turbulunce model in my USR Fortran routine. Is there a variable which stores the mass residuals? (I haven't found it in the manual :)) (Using CFX 4.4)
Thanks in advance!
Jan Rusås October 25, 2001 05:34
Re: Mass residuals
It is in the manual :)
You can declare all the residuals as a variable under
>>VARIABLE NAMES USER SCALAR1 'MASS RESIDUAL'
You must then read how to get acces to this variable in the actual usr. fortran you want to use , ie CALL GETSCA(......
Hope this is a help.
Jan
Hamsdi October 25, 2001 07:48
Re: Mass residuals
Thanks for the quick response. I still have a problem accessing the variable in my routine. The error text in the output file is as follows:
THE FOLLOWING KEYWORD HAS NOT BEEN PROCESSED
USER SCALAR1
I called it with
CALL GETSCA('MASS RESIDUALS', IRMASS, CWORK)
Thanks again ;-)
cfd guy October 25, 2001 10:55
Re: Mass residuals
Did you check out if you included the number of user scalar equations in the options of the command file? I'll give you a brief example:
--CFX4
--OPTIONS
THREE DIMENSIONS
BODY FITTED GRID
CARTESIAN COORDINATES
TURBULENT FLOW
ISOTHERMAL FLOW
INCOMPRESSIBLE FLOW
USER SCALAR EQUATIONS 1
--VARIABLE NAMES
Hope this helps,
Regards,
cfd guy
Hamsdi October 29, 2001 06:29
Re: Mass residuals
Thanks, now it works!
