Mass residuals
Old   October 25, 2001, 05:04
Default Mass residuals
Hamsdi
Hello, I want to check the mass residuals before choosing a turbulunce model in my USR Fortran routine. Is there a variable which stores the mass residuals? (I haven't found it in the manual ) (Using CFX 4.4)
Thanks in advance!
Old   October 25, 2001, 05:34
Default Re: Mass residuals
Jan Rusås
It is in the manual
You can declare all the residuals as a variable under
>>VARIABLE NAMES USER SCALAR1 'MASS RESIDUAL'
You must then read how to get acces to this variable in the actual usr. fortran you want to use , ie CALL GETSCA(......
Hope this is a help.
Jan
Old   October 25, 2001, 07:48
Hamsdi
Thanks for the quick response. I still have a problem accessing the variable in my routine. The error text in the output file is as follows:
THE FOLLOWING KEYWORD HAS NOT BEEN PROCESSED
USER SCALAR1
I called it with
CALL GETSCA('MASS RESIDUALS', IRMASS, CWORK)
Thanks again ;-)
Old   October 25, 2001, 10:55
cfd guy
Did you check out if you included the number of user scalar equations in the options of the command file? I'll give you a brief example:
--CFX4
--OPTIONS
THREE DIMENSIONS
BODY FITTED GRID
CARTESIAN COORDINATES
TURBULENT FLOW
ISOTHERMAL FLOW
INCOMPRESSIBLE FLOW
USER SCALAR EQUATIONS 1
--VARIABLE NAMES
Hope this helps,
Regards,
cfd guy
Old   October 29, 2001, 05:29
Hamsdi
Thanks, now it works!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
v & mass residuals azmir Siemens 0 January 4, 2005 06:11
CFX4.4 - mass residuals in 2D? Novak Elliott CFX 4 September 16, 2003 23:55
adjust a range of target residuals shown on mass a Jackie CFX 0 February 14, 2003 10:40
