November 7, 2001, 12:20 |
how to make hole in a solid in CFX-Build
In CFX-Build, I created a solid and want to make some hole in it. How can I do it?
November 8, 2001, 02:40 |
Re: how to make hole in a solid in CFX-Build
how does the solid look like and how should the hole too look like? Method depends on your geometry!!
November 8, 2001, 03:26 |
In CFX-4 you can create the "hole" as a solid that isn't included in the volume meshing, or simpliny leave a hole in the multiblock structure. In CFX-5, same thing really: create a b-rep solid exluding the hole surfaces, or cretae two solids, one for the entire geometry and one for the hole, and have a cutout solid in you domain definition. All of this I'm sure is shown in the tutorials. If you require more training, CFX also offers courses and one-to-one days to accompany you along your project set up...
November 12, 2001, 19:36 |
Hi beginner,
Please specify which CFX product you are using as the approach may vary. For CFX-5, create the surfaces which bound your solid (ie four flat surfaces, two trimmed surfaces with holes cut through them, and a cylinder). These surfaces may be combine into a <ib>Boundary Represented Solid</ib> (B-Rep). Regards, Robin |
How to make the water slightly compressible in CFX? | womo | CFX | 14 | February 12, 2020 06:20 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Elastic solid in CFX 10.0 | siavash ghassemi | CFX | 3 | October 18, 2007 03:54 |
CFX Build 5 question... | cfd guy | CFX | 6 | June 19, 2001 22:38 |
