help! cfx4.3 cfx-analyse has an error
cfx-analyse has an error: after I run file>load dump file,error is the following:
write: No error Error: A TASCflow sub-process (TASCtool) has aborted for an unknown reason. This may have been caused by an out-of-memory error or an internal error. Please increase the values in the Memory Manager panel, and try again. If the problem persists, please report this error to an ASC representive. Please help me!! increasing the values in the Memory Manager panel doesn't remove the error. Please help!!! thanks!!! |
Re: help! cfx4.3 cfx-analyse has an error
Two things: Do you have an analyse license running? (this could be the problem). Contact your CFX contact.
Sometimes it helps to reduce the amount of memory. Don't ask why.
Good luck, Pascale |
dear ..i think till now you have sorted out the prob ..but i would share my experience here .. this prob ..surprisingly sometimes almost nothing to do with memory .. i encountered this first when i changed the graphic card ..if it is an incompatible graphic card it will give this error ... so once check this .. second what i have experienced with cfx is .. it fails sometimes because the garbage collectin i.e. freeing of memory after a big run si not done properly so for it on NT machine i run chkdsk from run menu ... or other wise restart the computer ...if by changing memory it is not helping ..for sure it has nothing to do with memory .. and over the months with this software i know lot of places where error has nothing to do what it says
reply arjun |
| All times are GMT -4. The time now is 22:55. |
