help! cfx4.3 cfx-analyse has an error
Old   November 15, 2001, 07:55
Default help! cfx4.3 cfx-analyse has an error
Fish
cfx-analyse has an error: after I run file>load dump file,error is the following:
write: No error Error: A TASCflow sub-process (TASCtool) has aborted for an unknown reason. This may have been caused by an out-of-memory error or an internal error. Please increase the values in the Memory Manager panel, and try again. If the problem persists, please report this error to an ASC representive.
Please help me!! increasing the values in the Memory Manager panel doesn't remove the error. Please help!!! thanks!!!
Old   November 15, 2001, 09:43
Default Re: help! cfx4.3 cfx-analyse has an error
Herve
Two things: Do you have an analyse license running? (this could be the problem). Contact your CFX contact.
Old   November 15, 2001, 18:02
P.Fonteijn
Sometimes it helps to reduce the amount of memory. Don't ask why.
Good luck, Pascale
Old   November 27, 2001, 23:36
arjun s y
dear ..i think till now you have sorted out the prob ..but i would share my experience here .. this prob ..surprisingly sometimes almost nothing to do with memory .. i encountered this first when i changed the graphic card ..if it is an incompatible graphic card it will give this error ... so once check this .. second what i have experienced with cfx is .. it fails sometimes because the garbage collectin i.e. freeing of memory after a big run si not done properly so for it on NT machine i run chkdsk from run menu ... or other wise restart the computer ...if by changing memory it is not helping ..for sure it has nothing to do with memory .. and over the months with this software i know lot of places where error has nothing to do what it says
reply arjun
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
