November 22, 2001, 03:57 |
Mass flow rate
Dear all
When using the boundary condition inlet - > Mass Flow rate (kg /s-1) How are this b.c applied to the surface/domain ? Does it automatically covert to velocity at the inlet ? Thanks in advance. Regards User |
November 27, 2001, 16:30 |
Re: Mass flow rate
Which code? In both CFX-5 and CFX-TASCflow the inlet mass flow is applied locally at each integration point on the inlet after it is scaled by the total area of the boundary condition patch to get the mass flow per unit area: mdot,pua. Once you have that number then you simply set mdot,ip = mdot,pua * Aip. This way your total mass flow is distributed nicely across the entire boundary condition patch. Im not sure about CFX-4 but it probably does something similar.
Dan. |
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 09:58 |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 20:33 |
Mass flow rate at the outlet | tejasvikrishna | FLUENT | 2 | May 25, 2013 02:42 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 07:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
