January 4, 2002, 03:25 |
1 dimensional shock simulation
Does any one have experiance with setting up a one dimensional plane shock wave simulation?
If so I could do with all the help available |
January 7, 2002, 12:07 |
Re: 1 dimensional shock simulation
Hi Menon,
For simulation, all you need to do is to prescribe the left and right states for parameters like density,pressure and velocity to represent the shock(which is a discontinuity)for all the cells. This is the initial condition for the shock. Then as the computations are marched in time,you need to check how the shock propagates(use the maximum shock speed for defining the CFL(Courant-Friedrichs-Levy)no). Hope this clears your doubt. Regards gita |
Display Modes | |
Shock tube simulation in Fluent | Vinoo_P | FLUENT | 28 | September 6, 2018 01:21 |
shock absorber simulation | dik | FloEFD, FloWorks & FloTHERM | 2 | May 7, 2010 09:36 |
[ask] shock absorber simulation | dik | Main CFD Forum | 1 | December 17, 2009 02:32 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 14:46 |
TWO DIMENSIONAL JET FLOW SIMULATION | shriram | Main CFD Forum | 0 | June 20, 2007 14:48 |
