How can i define a inlet in a solid?
Old   November 29, 2001, 20:47
Default How can i define a inlet in a solid?
Haribort
Hi!everyone!I want to define a inlet in a solid.At first,i defined it directly in the solid,but when i ran the solver,i got the massage as:...the inlet does not contain a solid. How can i define a inlet in a solid? waiting for your help! thanks!
Old   November 29, 2001, 23:47
Default Re: How can i define a inlet in a solid?
arjun s y
i don't think it is plausible to define inlet in a solid ... how flow could be into the solid ...
arjun
Old   November 30, 2001, 02:11
Haribort
Hi, arjun s y,thanks again!
As you know,i'm working on a project about the two phases fluid of air-liquid.And the inlet of the air phase is at the bottom of the model(not under),so i must define a inlet in the model.But the size of the model is so different that it is not a good ideal to creat a solid directly in the model(¦Õ50-82000)(If you creat a solid in the model in bulid,and then delete it ,you can creat a patch ,the type is inlet or outlet,on it). Therefore i want to define a inlet directly in the model.What should i do?
By the way ,may you give me the answer of last time, a question about multi phases?
Thank you !
Old   December 3, 2001, 02:07
Li Xinfeng
Dear Haribort, Ur question is very strange, why u want to do a inlet in a solid? Do u think where the inlet come from? Best regards Sincerely yours LI Xinfeng
Old   January 11, 2002, 13:10
matej forman
If I'm getting it right - you mean solid as a object in build (block of geometry) and not a solid like the table or a piece of iron. Then - have a close look to the definition of your boundary condition. the inlet must be defined on the edge of the geometry - not inside, so one of I,J or K must be 1. You can check it in build, ( if using CFX4 is geo file or using analyse to see the position of you8r inlet bc. I think you got the message because you have got the wrong position of your BC or it has not properly defined physical patrameters.
hope this helps
Matej
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
how to write UDF to define 2 profiles at inlet? emma FLUENT 5 January 30, 2011 05:22
how to define inlet velocity for 2D ahsan FLUENT 0 July 15, 2009 23:04
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
