March 4, 2002, 07:00 |
Periodic boundaries at inlet and outlet?
How do I implement cyclic boundaries where all variable should be transfered excpet from the pressure in order to generate a mass flow where the outlet velocities (and all other variables) equal to those at the inlet? I would like to do so, in order to model a section of a (infinte long) piping system. I use CFX5-5.
Michael Bo |
March 4, 2002, 13:02 |
Re: Periodic boundaries at inlet and outlet?
You need to use translational periodicity + a momentum source to set the pressure gradient. You may have to iterate (manually) a little to get the mass flow rate you want.
Neale. |
March 13, 2002, 12:53 |
Does anyone have any experience with complicated 2D crossections and obtaining a truly periodic flow rate? For example say a square duct with four large fins sticking 1/3 the edge length towards the center. Is the momentum source simple ie constant everywhere, or is it a complex 2D function in order to create the periodic flow / pressure field? I'm just forseeing a complicated manual iteration process in front of me that I think the code should do for me, but maybe it's not as bad as I'm thinking.
One other option is to use Fluent because it has a periodic / fully developed flow boundary condition available directly to the user without messing around with source terms and flow rates: you can just set the pressure gradient OR the flow rate. |
March 14, 2002, 02:58 |
>you can just set the pressure gradient OR the flow rate. That's because the pressure drop is a function of the flow rate and vice versa; e.g. in laminar flow cf=64/Re.
March 15, 2002, 02:24 |
I've been talking with CFX and they will probably include a peridoc boundary with specification of mass flow: "I have requested that the boundary condition your require be in a future release."
Display Modes | |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Periodic BC on Inlet and Outlet of a Duct | Steve | CFX | 2 | August 8, 2005 12:03 |
outlet = inlet in a periodic geometry | Stephane bone | Siemens | 3 | January 20, 2005 03:26 |
Inlet & Outlet Boundaries causing low surface temp | Ted Crilly | Siemens | 2 | November 19, 2004 08:58 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
