Home > Forums > CFX
error
Old   February 6, 2002, 06:20
Default error
Jennifer Haque
Hi
I have got the following error coming up when I try to create/surface/trimmed.
''curves to be chained are not contiguous due to a gap of 0. The point of discontinuity has been marked''
What does this mean?
Can anyone help?
Jennifer
Old   February 7, 2002, 09:55
Default Re: error
stuart
Hi Jennifer, this usually means that there's a gap in your curves. There are usually more than one way to create things in Build, and sometimes one option works better than another. Have you already chained your outer and inner curves ?? if so did you pick the edges of a surface to create your chained curve or just explicit curves. Try one or the other. If you still can't creat a chained curve then use show/point/location to check that the end points of curves match up, or even zoom right in to the ends of the curves to check they exist at the same location (use the zoom + and - buttons to get real close). Any other questions just email me, good luck Stuart
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
