gas-solid fluidization
Old   February 26, 2002, 00:24
Default gas-solid fluidization
cfxusers
I am using CFX4 to simulate gas-solid fluidization. In acdemic literatures, the kinetic theory of granular flow is used. The CFX4 also use it. But the document in CFX4 seems not very clear. The default model is so called "CRC model', and the alternative is the so called 'Delft model'. The correlations about kinetic theory in CFX document also puzzled me. Is it about CRC model or Delft model. Does anyone know it? Thanks.
Old   March 6, 2002, 09:05
Default Re: gas-solid fluidization
Ribeiro
Hi Yang
The diference is in the GAMMA term (the dissipation of energy). Looking at the eq. 15 of the paper SIMULATION OF PARTICLES AND GAS FLOW... of Benyahia et al. from Powder Tech 112 (2000) 24-33, you can see two term that compose the GAMMA term.
In CRC Model the eq. 15 is treated as it is in paper. In Delft Model the eq. has no the term GRAD(V) - the last term. Thus it is possible to get an analytical solution.
REgards
Old   March 7, 2002, 07:41
yang
Dear Sir,
Thanks for your help. You mean the two model is only different in the correlation of disspation term. Delft model neglect the gradient term. But I am still a little puzzled.The CFX document (page 3-770/771. Solver) show the temperature equation (Eq. 3-383) is only composed of generation and dissipation terms, neglecting the convection and diffusion terms. This leads to an algebraic expression. Is it about CRC model or Delft model or nothing?
Yang
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Gas Solid Fluidization ANKW FLUENT 1 November 21, 2009 10:13
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
