CFX-Hexa documentation
Old   February 22, 2002, 06:57
Default CFX-Hexa documentation
pperic
Where can I find CFX-Hexa online documentation and tutorials?
Thanks, Pero
Old   February 24, 2002, 09:55
Default Re: CFX-Hexa documentation
Astrid
Try the helpdesk, but I think they will forward you to ICEM-CFD.
Astrid
Old   February 25, 2002, 03:50
pperic
Thanks Astrid
Anather question.
I'm a new in Tascflow (fluent user). How are you import your geometry in CFX-HEXA (or ICEM-CFD)? Can you describe me your path of mesh preparing?
Thanks, pp
Old   February 25, 2002, 16:14
Astrid
In fact, I don't know CFX-Hexa but do know ICEM-CFD. Assuming they work the same you can try the following:
Make a draft version of your geometry in a CAD-package (Pro-E, Solidworks, Catia) or in CFX-Build. By a draft version, I mean the outline of the geometry (corner points, lines and outer surfaces). Then export it to an IGES-format and read it in CFX-Hexa. There make the internal block structure.
Succes, Astrid
Old   February 26, 2002, 10:14
pperic
Thanks Astrid,
Did you meen in ICEM-CFD (for iges importing) ?
ImportGeo: Iges --> Tetin
Thanks pp
Old   March 1, 2002, 09:32
David Minns
Hi, I haven't seen CFX HEXA but if it's the same as ICEM CFD HEXA then the best route for CAD import depends on your CAD system. If you have one of the following,
CATIA, PROE, UG, IDEAS, solidworks, ICEM SURF then use a direct interface (DIF). If you don't then use IGES.
Regards
David
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
