Mashing Problem?
Old   March 3, 2002, 00:31
Default Mashing Problem?
ji
dear all,
I got this message in cfx 5.4.1 build when i try to mashing.
"Zero length stack generated"
and then I can not write the diffinition file.
But when I run the example such as staticMixer, I don't have this message.
dear all,
I got this message in cfx launcher when i try to run the solver
CFX-4 | Solver | forrtl: error (72): floating overflow
CFX-4 | Solver | Image PC Routine Line Source CFX-4 | Solver | psolvempiNT.exe 00687065 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0062000B Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 005BBB86 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0053552B Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 00492B77 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0042D97E Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 00419CE5 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040B73B Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040541C Unknown Unknown Unknown CFX-4 | Solver | CFX-4 | Solver | Stack trace terminated abnormally. CFX-4 | Solver | runsolve4: Job completed CFX-4 | Solver | Output file : /CFX_Work/m93.fo CFX-4 | Solver | CFX-4 | Solver | Finished. CFX-4 | Solver |
What causes this and how do we avoid it? Thanks
Ji
Old   March 3, 2002, 08:12
Default Re: Mashing Problem?
Richard
maybe you should change the time steps
Old   April 4, 2002, 05:03
Steve
Hi Ji
The "zero stack length generated" error, is due to 3 sided surfaces which is poorly parameterised and has an edge length of zero.
Go to Geometry > Show > Surface, then highlight all surfaces and apply. Look down the list of surfaces and you will see the problem surfaces have 4 sides but 1 side is zero, therefore 3 sided.
There are 2 methods of solving this, join the problem surface with an adjoining surface to create a large trimmed surface, or re-create the surface as a trimmed surface.
You could also check to see if any of the edges of the problem surfaces are not smaller than the tolerance.
Steve
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
