Home > Forums > CFX
Visualiser Problem
Old   March 26, 2002, 06:26
Default Visualiser Problem
a.melandinos
Is there any other way or program to visualise results (*.fo file) outside CFX? Because I am working in CFX4.3 without the postprocessor license. (I have only Preprocess and Solve). Thank you in advance
Old   March 26, 2002, 09:43
Default Re: Visualiser Problem
Astrid
You cannot visualise .fo files. You can only 'visualise' *.dmp or *.dump.* files.
You could use FieldView but I don't think you have a license for that if you don't have a license for the CFX-post processing programs. Nevertheless, what can you do without a postprocessing license? Write everything to file using Fortran routines and use Excel sheets or what?
Astrid
Old   March 26, 2002, 12:17
cfd guy
Astrid is right, you can only work with dump files. However if your geometry is quite simple you can play with the USRTRN subroutine and extract all the info that you want.
Regards, cfd gut
Old   March 27, 2002, 04:02
Neale
If you don't mind writing code yourself, then you could output the data into files and then read them into something like Visual3 or Vis5D (which are free).
Old   March 27, 2002, 11:59
windhair
I think you can generate your own output data file using Output option.
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
