April 17, 2002, 17:51 |
Scalar summation over whole volume
I would like to sum a user defined scalar, over a whole simulated volume at each time step. Has anybody done this? I have tried by using Fortran in the USRTRN subroutine. I am using CFX4.4. Thanks for your help, Jakub |
April 18, 2002, 08:34 |
Re: Scalar summation over whole volume
If you're sure that you're solving your user scalar correctly, you can use USRTRN to extract the values that you want. For the whole domain you can take a look at the IPALL routine. It's quite easy to obtain values from variables using this sub-routine. Good Luck, cfd guy |
April 18, 2002, 13:21 |
Thanks,
I finaly realised that I deeded to use the IPALL utility routne. Such a stupid mistake to make ;-) Kuba B. |
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
