Calculation of cell areas in USRTRN
Old   May 6, 2002, 06:36
Default Calculation of cell areas in USRTRN
Søren
Hi !
I've a encountered a problem in finding the area of a cell when using USRTRN
I need to calculate the area of each gridcell in for example the j direction. How do adress this?
So far I've tried the area(Nface,3) command, but I'm, not quite sure that I've done it right.
Søren
Old   May 7, 2002, 11:59
Default Re: Calculation of cell areas in USRTRN
cfd guy
I believe that the easiest way is to create an USER2D patch under your meshing tool. Once you've created this patch you can use IPALL (or IPREC) to extract the data that you want.
Good luck, cfd guy
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 11, 2012 23:13
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
