Home > Forums > CFX
Ading User Scalars
Old   May 8, 2002, 09:05
Default Ading User Scalars
Rhydar
Hi all,Continuation of the last message. Am getting an error when I try to add a user scalar. CFX 4.4. Fully Compressible, Transient, 2D. Want to add 'REAL PRESSURE' as the scalar, but can't get to the option in the command file "SETUP COMMAND FILE" and not recognising the line if I add it in edit command file. Is there a known bug? Or some step that I am missing out on. Thanks in advance.
Old   May 8, 2002, 10:54
Default Re: Ading User Scalars
cfd guy
Under Setup, go to OPTIONS and choose the number of user scalars. If you want to know only this REAL PRESSURE, number is 1. Then go to VARIABLE NAMES and set this up:
USER SCALAR1 'REAL PRESSURE'
That's it. Regards, cfd guy
Thread Tools
Trackbacks are On
USER DEFINED SCALARS yann Phoenics 6 November 14, 2013 09:46
(DPM) Names for User Scalars (instead of Use Variable 0)? sega Fluent UDF and Scheme Programming 3 April 20, 2010 07:33
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 18:18
User viscosity routine and user scalars? Jeff CD-adapco 3 January 6, 2003 06:26
Naming User Defined Scalars Greg Perkins FLUENT 0 March 7, 2000 00:10
