May 24, 2002, 05:07 |
Error code...
Howdy,
I was trying to run a laminar transient calculation in parallel (using CFX 5.5), when it suddenly stopped and informed me that An error has occurred in cfx5solve: The CFX-5 solver exited with return code 1. No results file has been created. End of solution stage. I haven't located what these return codes actually mean, so if anyone could help me out, or point me in the right direction, I would be more than grateful. By the way, this calculation worked fine on one processor. Thanks, Gustaf |
May 24, 2002, 10:23 |
Re: Error code...
The return code of 1 simply means that the solver run did not complete normally. A return code of zero means normal completion.
Is there an error message in the output file? Neale |
