usrbcs for inlet boundary
Can anyone help me with this problem?
I am trying to set up a time varying boundary condition for an inlet of air from a diffusor. The diffusor is implemented as a patch with a time varying velocity of air. My problem is that I canīt associate the velocities defined in fortran with the patch in the command file, ie. i donīt get an inlet of air in the output file. The piece of code defined in Fortran USRBCS is: CALL GETVAR('USRBCS','V ',IV) CALL IPREC('BELUFTER1','PATCH','CENTRES',IPT,ILEN,JLEN, KLEN, + CWORK,IWORK) DO 702 k=12,15 DO 701 j = 1,1 DO 700 i=7,7 inode =ip(i,j,k) varbcs(iv,2,inode)=1.0 700 continue 701 continue 702 continue The system is a multi fase system, and air is phase number 2. The inlet velocity is in the y-direction, normal to the tank bottom. Regards Jesper Laursen, University of Aalborg, Denmark |
Re: usrbcs for inlet boundary
Why don't you use IPALL instead of using the IPREC utility subroutine? It would be something like this: CALL GETVAR('USRBCS','V ',IV) CALL IPALL('BELUFTER1','*','PATCH','CENTRES',IPT,NPT,CW ORK,IWORK) DO 200 I=1,NPT INODE=IPT(I) VARBCS(IV,2,INODE)=1.0 200 CONTINUE This may work. Good luck! cfd guy |
Hi cfd guy.
Thanks for your reply. I found out that the problem was related to the way the patch was defined in the command file, but now it works. Regards Jesper Laursen |
