June 17, 2002, 06:20 |
Iteration from dump file
Hi all,
I am a new CFX4.4 user on windows NT. I have do run my simulation that take a long time. When I set max. iteration as, say, 6000, I still see that there is still some convergence. Now I want to continue further interation from where i left, (6000 iterations). Is this possible from the dump file, if so haow do you do it? regards Nyatoto |
June 17, 2002, 06:51 |
Re: Iteration from dump file
In the Solve GUI there is an 4th option down 'Restart from File'. Just write 'Latest' or the number of the dump file you want to start from.
Kuba |
June 17, 2002, 08:04 |
Hi Kuba,
thanks, let me try it. regards nyatoto |
June 23, 2002, 08:51 |
Just one word of warning, make sure that you remove the initial guess option from your command file for the restart, otherwise the dump file data will not be used.
James Date |
June 27, 2002, 06:09 |
Hi James,
Thanks, I was not quite certain that the retart was working as expected. I will do that now. regards nyatoto |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
