-   -   plloting radial and axial velocity (http://www.cfd-online.com/Forums/cfx/19071-plloting-radial-axial-velocity.html)
hamza July 16, 2002 15:20
hi anyone,
iam using CFX5.5. i want to plot (chart) an axial velocity profile at the center of the pipe an plot the radial velocity profile at specific point a long the axis. for example, the pipe lenght is x=2m and diameter is 1m how i can plot axial velocity vs x=2m at 0.5 m (center of the pipe) and plot radial vlocity vs radius at specific x=0.5m. Is there any procedure to do that? if you can tell me the procedure in detail.
thank you
cfd guy July 16, 2002 15:34
Re: plloting radial and axial velocity
Hi, To plot any chart, first you must create a polyline. To create a polyline you may take a look at the online manual or read some posts regarding this discussion which was already commented:
http://www.cfd-online.com/Forum/cfx_....cgi?read=1838
Good luck, cfd guy
JOSE MARA July 17, 2002 13:21
Estimado colega de uso del CFX-5.5, para crear un chart en el cfx post, debes editar un archivo con las coordenadas que quieras que siga la curva, en un archivo con extencion *.txt (Notepad, wordpad,etc). De la siguiente forma:
Velaxial.txt 8 0.5 0 0 0.8 0 0 1.0 0 0 1.2 0 0 1.4 0 0 1.6 0 0 1.8 0 0 2.0 0 0 Este es el archivo txt con 8 puntos de monitoreo a lo largo del eje axial (coordenadas espaciales (x y z)). Una vez creado el archivo, tu crearas una polyline en el post procesador con las siguientes caracteristicas: Method: From file Imput file: Velaxial.txt Apply
Se creara una linea sobre tu modelo. Ahora tu crearas tu chart de la siguiente forma:
New
Locator: Polyline 1
X axis: X
Y axis: Velocity u
Apply
View chart De esta forma obtendras tu grafica. Para la velocidad radial haces lo mismo....
Espero que entiendas mi espaņol. Okey.......
hamza July 18, 2002 01:12
hi jose
i could not understand your language if you can write the explination of plotting axial and radial profile in english.
thank you
hamza July 18, 2002 01:40
hi jose mara
if you can explain how to plot an axial and radial profile in english
thank
Edward! May 31, 2010 16:42
Que tal jose mara es dificil encontrar personas que hablen espaņol por aqui en fin de casualidad sabes si existe un tutorial de gambit o alguna otra cosa para hacer un mallado de un alabe de turbina en 2D busco hacer un mallado exactamente como lo indica la siguiente imagen muchas gracias
Saludos Eduardohttp://co103w.col103.mail.live.com/a...CCAF4817F4F0||
