inflation
Old   July 15, 2002, 19:41
Default inflation
Hannah liang
Hi, all cfd friends, I always have troubles when i use the inflation. the definition file could be writen when no inflation but failed if i add inflation. pls give me some advice.
Thanks a lot
Hannah
Old   July 18, 2002, 07:55
Default Re: inflation
henry
hi,
you got to read the error message carfully and then hightlight the region of error ,and in that surface give appropiate mesh controls and it will be fine.
Some times you have to play with the mesh control numbers - mesh size
hope tihs solves your problem
henry
Old   July 18, 2002, 14:19
Default Re Inflation
TheOneOnTheRight
Hi, quite often if you can produce a volume mesh without inflation, but can't with inflation it can be due to either two surfaces being too close together for the correct amount of layers to be included - this should be easy for you to check. It could also be due to some rogue CAD geometry which has produced a poor surface mesh, which does not allow inflation to be produced. You can use the CAD quality checker to highlight poor surfaces. Hope this helps.
Old   July 19, 2002, 15:41
Default Re: Re Inflation
Hannah liang
Thanks for TheOneOnTheRight's advice. Could you tell me where I can find the CAD quality checker in the CFX 5.5
Thanks again
Old   July 20, 2002, 14:32
TheOneOnTheRight
No problem, its in Build under Tools\CAD Quality Check.. It will only allow you to do this after you have completed the domains form.
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 03:22
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
question about inflation for impeller sandy CFX 4 August 8, 2007 09:03
Inflation Gab CFX 6 August 24, 2005 22:45
inflation Jennifer Haque CFX 2 June 9, 2004 18:55
