July 22, 2002, 12:13 |
Help: 2D model in CFX 5.5
I hope to reduce my 3D model to 2D model to save the computation time. Now I use a B-rep sold to represent a 3D cylinder. I hope to rebuild a model in a 2D asymmetric model. However, is seems that CFX 5.5 Builder can not build 2D model. Is this true that CFX 5.5 only generate mesh for 3-D solid? Thank you very much. |
July 24, 2002, 00:25 |
Re: Help: 2D model in CFX 5.5
You'll need to create a cylinder slice that is only one element thick. You should use the Patran meshing tools to do this (change the Meshing Mode). You can download documentation on using the Patran meshing tools from the CFX community site. Regards, Michael.
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
where to set CFX Transition Model? | steven | CFX | 6 | January 17, 2007 11:19 |
CFX to model convection cells | FER | CFX | 4 | December 13, 2006 00:57 |
Does CFX can calculate within structure model? | prayskyer | CFX | 9 | November 28, 2006 23:13 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 08:50 |
