Home > Forums > CFX
Mass flow = 0 on opening
Old   July 30, 2002, 15:42
Default Mass flow = 0 on opening
Jens
I have a model with large number of inlets, outlets and few openings. Unfortunably, the database file for this problem is not working anymore due to disk error.
I would like to try to close 3 openings in the model.
It is possible to specify an opening with Zero Mass Flow rate ???
How will this influnce on the model,- does it work as a wall or ???
Thanks a lot in advance.
Regards
Jens
Old   July 31, 2002, 07:14
Default Re: Mass flow = 0 on opening
Tommaso
Hi Jens, yes , it's possible to specify an opening with zero mass flow rate defining it as MASS FLOW BOUNDARY and setting in command file or in USRBCS the zero flow condition.I have found a better convergence using the fortran subroutine.This type of patch works as a closed sect rather than a wall.
Regards
Tommaso
Old   August 2, 2002, 18:13
Jan Rusås
If you just want the old openings to be walls, you can just remove them in the geometry file. Remember to adjust the number of patches.
Thread Tools
Trackbacks are On
[CFX] Target Mass Flow Opening minger CFX 0 August 24, 2011 18:34
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
different mass flow rates michael FLUENT 4 February 21, 2005 03:48
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
