July 31, 2002, 15:22 |
cfx4 parallel sover Problem!! HELP
I am using cfx4 to solve a fluidisiation problem (gas-solid multiphase problem)
when I run my job sequentially everything is fine. When I try to run the same job (from scratch) using the parallel solver, I get problems (initial conditions set by USRINT does not comply anymore) with the physics of my problem. does anyone know why? Is it ok to use USRINT in parallel jobs? Am I supposed to change the 'block' information in the IPAL and IPREC utility routines when domian decomposition is used? Any help would be very useful. cheers |
August 1, 2002, 10:25 |
Re: cfx4 parallel sover Problem!! HELP
Hi Richards,
You're using USRINT to fill your model with solids at a certain height, isn't it? If you're not using another subroutine you can run a serial job, starting from scratch and using USRINT, with only 1 iteration and then restart a parallel job using this dump file. But I must warn you, CFX-4 parallel doesn't work very well. Regards, cfd guy |
August 3, 2002, 03:54 |
Thanks for your help 'cfd guy'
I managed to get some advise from cfx regarding my fortran file and command file. cheers |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
[snappyHexMesh] processorWeights problem with snappyhexmesh in parallel | oskar | OpenFOAM Meshing & Mesh Conversion | 0 | July 7, 2011 10:05 |
Parallel UDF problem, hello world version | pilou | FLUENT | 0 | March 10, 2011 08:20 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
