August 19, 2002, 02:41 |
Hydrostatic pressure in 5.5
I have a problem with the setup of a large high tank (70 meter) which is filled with water. I have set the hydrostatic pressure within the tank since it is fill with water, but has no free surface. As far as I can see the only way to do this is to use the free surface model, but the problem has no free surface. Does any on has a hints ? Thanks a lot. Regards Jens |
August 19, 2002, 21:22 |
Re: Hydrostatic pressure in 5.5
Hi Jens,
There was a long discussion of this topic sometime last year on the forum. See this thread for explanations: http://www.cfd-online.com/Forum/cfx_....cgi?read=1457 Regards, Robin |
August 21, 2002, 09:11 |
Hi
Thanks for the reply. But I still think the answer are bit confusing, since as I understand CFX-5.5 does no include total sum of pressure only there relative pressure distribution. (So it does no have hydrostatic pressure) So in order to visulize it I have to include into CFX-Post and add it to relative pressure. That seems strange, since there are a lot of cases where it does matter. It this assumtion okay ? Regards Jens |
August 21, 2002, 11:05 |
Hi Jens,
This is no longer the case in 5.5.1. The hydrostatic pressure contribution is included in the Pressure, plus an additional vector, Buoyancy Force, is also provided. Regards, Robin |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
vof + hydrostatic pressure | ariorus | FLUENT | 0 | August 7, 2009 10:57 |
hydrostatic pressure influence | pdz711 | FLUENT | 0 | June 17, 2008 22:33 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
