Hydrostatic pressure in 5.5
Old   August 19, 2002, 02:41
Default Hydrostatic pressure in 5.5
Jens
I have a problem with the setup of a large high tank (70 meter) which is filled with water.
I have set the hydrostatic pressure within the tank since it is fill with water, but has no free surface.
As far as I can see the only way to do this is to use the free surface model, but the problem has no free surface.
Does any on has a hints ?
Thanks a lot.
Regards
Jens
Old   August 19, 2002, 21:22
Default Re: Hydrostatic pressure in 5.5
Robin
Hi Jens,
There was a long discussion of this topic sometime last year on the forum. See this thread for explanations:
http://www.cfd-online.com/Forum/cfx_....cgi?read=1457
Regards, Robin
Old   August 21, 2002, 09:11
Jens
Hi
Thanks for the reply. But I still think the answer are bit confusing, since as I understand CFX-5.5 does no include total sum of pressure only there relative pressure distribution. (So it does no have hydrostatic pressure) So in order to visulize it I have to include into CFX-Post and add it to relative pressure.
That seems strange, since there are a lot of cases where it does matter.
It this assumtion okay ?
Regards
Jens
Old   August 21, 2002, 11:05
Robin
Hi Jens,
This is no longer the case in 5.5.1. The hydrostatic pressure contribution is included in the Pressure, plus an additional vector, Buoyancy Force, is also provided.
Regards, Robin
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 10:57
hydrostatic pressure influence pdz711 FLUENT 0 June 17, 2008 22:33
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
