How to Model Three Phase Clay Slurry in CFX 5.5
Old   August 26, 2002, 23:52
Default How to Model Three Phase Clay Slurry in CFX 5.5
J.Yang
Hello everyone,
I would like to model the movement of the clay slurry in the thickener. The clay slurry consists of at least three fluids: dispersed solid phase --sand, dispersed solid phase -- clay and continuous phase of water. In CFX 5.5.1 at most two fluids can be modelled. So anyone know how I can resolve this problem.
Thanks in advance!
J.Yang
Old   August 27, 2002, 14:51
Default Re: How to Model Three Phase Clay Slurry in CFX 5.
Neale
Actually, you should be able to set up N phase problems in 5.5.1. Where does CFX-Build say you can't?
Neale
Old   August 28, 2002, 12:06
J.Yang
Thank you. I got it.
J.Yang
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Flash Process / Problem with thermal phase change model Ridley CFX 0 July 21, 2010 07:57
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 06:27
