-   CFX (
-   -   donīt getting file .res (
alex September 6, 2002 09:37
hi everybody,my problem is Iīm not getting de file .res when the solver manager finishes the run, i donīt get the advice "has finished normally"....I donīt Know whatīs happening
please help me..
thanks a lot to all.. astrid, robin..
Astrid September 8, 2002 04:14
Re: donīt getting file .res
I sometimes have a similar problem with 5.5.1 under Win2000. Then the .res-file cannot be created for some strange reason. Do you have the same configuration? In the temporary directory, you can find the file called 'res' with the same content as your .res-file but with a different name.
If this doesn't help you, a work around is to rely on backup files. Create a backup file, one iteration before the run is supposed to stop. This backup file is similar to a res file.
I can't figure out what the real problem is, based on your information. This is what you actually want to solve, of course. Do you have enough drive space left?
alex September 9, 2002 11:37
hi astrid, thanks a lot for your answer, well i am using CFX-5.5 and windows 2000 professional, i*ll try to do that. i have run with 100 timesteps and i have lost this information, i am worry for this.
