average value in any plane
Old   October 16, 2002, 03:10
Default average value in any plane
Roy Chen
Hi~everyone i have a question about CFX see this pic(http://oz.nthu.edu.tw/~g903159/CFX/temp.jpg)
i want to know the data of any plane for example: in X-Y plane,i want to know average temperature (not distribution) of each plane,along Z axle. so i can plot a XY average temperature vs Z graph
can someone tell me how to do it?
Best wishes Roy Chen
Old   October 16, 2002, 15:49
Default Re: average value in any plane
Astrid
In CFX Post you can calculate the average temperature using the calculator. Just select the plane of interest and the value you want to know on that plane. You will find out that you can calculate a lot more than only the average value.
Astrid
Old   October 21, 2002, 10:06
Neale
If you only have a few planes then I would suggest just doing this by hand in CFX-Post. If you have many planes that you need to do this on then you should create a session file in CFX-Post for a single plane and the average, then go back and insert perl power syntax in the session file to create the other planes and averages that you need.
Neale
Old   October 22, 2002, 07:50
Roy
Thank you very much for your help. I am a beginner of CFX-4. Would you please tell me what is "session file" and where I can find the description of session file. Thank you again for your help.
Old   October 22, 2002, 15:24
Neale
Hi Roy,
You are using CFX-4. The answers that I gave you only apply to CFX-5. Perhaps there are some CFX-4 experts out there who can answer your question for you, or your support person (most likely the best approach).
Neale.
Old   October 22, 2002, 16:52
cfd guy
Hi Roy,
Analysing the picture I suspect that you want the average temperature only for a side of the wall. I also saw that you have only 1 block. So, go back to BUILD and create a customized wall (under Create Patch 2D, e.g. WALL_1) and use the IPREC utility under the USRTRN subroutine. Inside this subroutine you can calculate the average temperate over the whole face of a block.
Good luck, cfd guy
Old   October 22, 2002, 17:32
Astrid
The CFX-4-dump file can be used in CFX-Post. Consequently, my previous posting and Neale's posting are still valid, provided you have CFX-Post.
Astrid
Old   November 14, 2002, 11:17
windhair
You can get it by setup a patch data output in OUTPUT option. It will be look like this
:>OUTPUT OPTIONS
:>FLOW STATISTICS
>>PATCH DATA
PATCH NAME 'wal11'
FILE NAME 'wall.dat'
AVERAGE
TEMPERTURE
EACH ITERATION
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Average of Y velocity components along a plane Natesal Siemens 0 September 28, 2007 12:58
calculation average pressure in a plane with UDF Vitalij FLUENT 1 April 10, 2007 03:39
average value in any plane aloise CFX 3 July 26, 2006 15:30
