-   CFX (
-   -   Moving grid (USRGRD) example? (
Novak Elliott November 7, 2002 06:47
Hello, I am looking to model squeeze flow in the bearing gap of a thrust bearing that is moving with simple harmonic motion using CFX (4 or 5). The fluid domain needs to be resized at each timestep. I understand this is called a 'moving grid' problem and requires the use of the USRGRD user routine.
I am having trouble getting started as I cannot find any examples to understand how this sort of model is set up and solved. Are moving grid problems a black art?
Can anyone point me in the right direction? All responses are greatly appreciated.
cheers, Novak.
cfd guy November 7, 2002 08:33
Re: Moving grid (USRGRD) example?
Hi Novak,
Once I've worked with moving grids in CFX-4. I can say that you can move your nodes using algebraic functions in conjunction with IF Statements in your subroutine. I can send you what I did in the past. Regarding moving grids in CFX-5 I don't know how to proceed or if it's already implemented.
Regards, cfd guy
Glenn Horrocks November 7, 2002 19:09
Hi Novak,
I will email you a copy of the user fortran code I used to do transient grids in modelling internal combustion engine flows.
My code works (in CFX 4.3) by reading in the CFX geometry file (m01.geo by default), applying a transformation to the original points locations to give new point locations (the tranformation can be a function of time, space or anything) and then uses the new points as the grid for the next time step.
