September 30, 2002, 17:41 |
Creat Thin Surface
Hi, Guys:
Is anybody can give me an example of how to creat a thin surface. Thanks |
October 1, 2002, 02:55 |
Re: Creat Thin Surface
In CFX 5? Check the manual on thin surfaces and subdomains.
Astrid |
November 20, 2002, 15:32 |
You have to creat subdomain in your domain. and you can then specify it's surface to be a thin wall.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
