Pointers to wall adjacent cells in CFX 5
Old   November 19, 2002, 03:43
Default Pointers to wall adjacent cells in CFX 5
Fabian
Can somebody suggest how I can obtain the pointers to wall adjacent cells in CFX 5? Or give me some advise how I can put different sources of a passive scalar in the wall adjacent cells than in the cells in the main flow field. In CFX4 I solved this question via the FORTRAN subroutine "IPALL". Do I have to do this also via Fotran in CFX5 or can I make use of the CEL? Thanks
Old   November 21, 2002, 11:07
Default Re: Pointers to wall adjacent cells in CFX 5
Neale
Can you set your additional variable source as a flux through the boundary (i.e., units/m^2)? If so then you can use a CEL expression or a CEL user fortran routine.
If you need a volumetric source to be applied in boundary control volumes then this will require special coding.
Neale.
Old   November 21, 2002, 11:14
Fabian
I need to put volumentric sources. What I want to do is to program my own wall-functions for my passive scalars. So who do I get the pointers to the wall adjacent cells? Cheers Fabian
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
how to specify a wall as porous wall in CFX nagarjuna reddy CFX 3 June 3, 2010 08:03
Selecting Wall Cells for Drag Force Mr. Javidan Ahmad Siemens 3 May 13, 2005 22:20
