Editing the command language file
I am using CFX 5.5.1 on windows NT machine. I want to edit the command language file (CCL). I used following command to generate the CCL file: c:\temp>cfx5cmds -read -definition < polylin > -text < swapnil > where polylin is my def file and swapnil is name of the CCL file that will be created. temp is my working directory. I am getting following error "The syntax of the command is incorrect." I have written the command as per mentioned in the manual. can anybody please tell me why i am getting this error message. Thanks, Swapnil. |
Re: Editing the command language file
I always use:
cfx5cmds -read -def <def-file> -text <text-file> Hope this helps, Astrid |
Re: Editing the command language file, New Error
Hi Astrid,
I used the following command. It's giving me the new error that the definition file (test.def in my case) does not exist. I double checked that test.def is present in my working directory i.e. temp. What do you think could be the reason behind this? Thanks, swapnil COMMAND: c:\temp>cfx5cmds -read -def test -text swapnil ERROR MESSAGE: An error has occurred in cfx5cmds: The specified CFX-5 Definition File test does not exist. |
CEL file,Got the answer
Hi Astrid,
Previously I didn't enter the file name as test.def ( i enterd only test). That's why i was getting the error. Now it's working ok. Thanks for the help. Swapnil |
Hmmm. I see that the message I posted is not represented correctly. Text between '<' and '>' is lost somehow. What I meant to write was:
cfx5cmds -read -def test.def -text text.txt But you have found the answer already. I am glad it helped somehow. Astrid |
