November 14, 2002, 07:28 |
Reaction region in CFX 4.3
Ini my simulation, the chemical reaction only occur in part of the flow field, so I need to create block or patch to build the reaction region, but how to define this region as reaction only take place? It is possible in CFX 4.3, by user subroutine?
Thanks |
November 14, 2002, 18:01 |
Re: Reaction region in CFX 4.3
You have to create a USER3D patch, either in the command file or in CFX-Build. In this region reaction can take place exclusively. For this you have to program some user fortran...
Astrid |
November 15, 2002, 03:46 |
I thought I must do it in the method you described. I have create the 3Dpatch, and plan to write user subroutine. But what is the main function or subroutine I should use? I have no idea after I read all the mannual about fortran subroutines. who can tell me some more detail? Thanks
windhair |
December 8, 2002, 12:11 |
If you have set up the reactions in command language, then use user fortran USRRAT. I would then set the 3D Patch to be all reagions where you want zero reaction. In USRRAT.F, set the reaction rate to zero for the given patch.
John |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
reaction in UDF(DEFINE_VR_RATE) | louiza | FLUENT | 3 | October 13, 2010 23:59 |
CFX Monitouring on the region in domain?? | july | CFX | 3 | September 28, 2007 10:46 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
