Can't see the line in Static Mixer problem.
Old   December 17, 2002, 11:56
Default Can't see the line in Static Mixer problem.
Atit Koonsrisuk
Dear all, I am the newcomer of CFX. Now I am using CFX 5.5.1. My OS is Windows2000. After finishing the installation process, I follow the "Running the Example" section, in "Getting Started with CFX-5" of "Installing and Introduction to CFX-5" manual. The result is all right.
To practice using CFX, first, I follow the tutorial in "CFX-5 Tutorials". I follow the instruction in "Tutorial 1: Flow in a Stator Mixer" step by step. After following the step to create the first curve, in "Creating the Main Body", The result in output command is "$# 1 Curve Created: Curve 1". However I cannot see that curve. I tried to follow the succeeding steps, I also cannot see the second line. But it seems like CFX recognize that there is that curve.
I delete all files contain in the working folder, then restart my PC. Then try to do those steps. However I got the same result. I try to do many ways but the result is still the same.
However, today, I do the same step, and I get that curve this time. I do not know why. Then I am not sure if it will occur again or not.
Can anyone explain to me about this?
Thank you very much.
Atit
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
Meshing problem Andrea_85 OpenFOAM 1 January 13, 2011 09:36
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
line problem popcool FLUENT 1 December 12, 2002 12:04
