Home > Forums > CFX
Interfacial length scale in mixture model
Old   December 26, 2002, 11:42
Default Interfacial length scale in mixture model
Andrew
For air-water system, using mixture model, what's the value for the interfacial length scale? Is it the molecular diameter, for example 10^-9m?
Regards Andrew
Old   December 27, 2002, 11:29
Default Re: Interfacial length scale in mixture model
Holidays
Hi Andrew, I guess that if your are using a continuous/continuous approach (ie not disperse/continuous)this is the length scale that is going to be used to mimick the surface contact area that is used to model drag for example in a diperse/continuous approach. In this case the scale is more on a "bubble diameter" sort of order.
Old   December 27, 2002, 20:19
Andrew
Thanks a lot. Yes I want to use continuous/continuous approach not a disperse/continuous one. Could you please give me a range for the length scale, so I can select an appropriate value to start my simulation? Normally a bubble diameter has unit of 'mm'. According to your reply, is '1cm' OK or more? Looking forward to your answer.
Regards Andrew
Old   December 30, 2002, 08:38
Holidays
Hi Andrew,
I think that the formula for the interfacial exchange is in the multiphase notes of the on-line CFX-5 manual (I don't have it with me, but look for the interfacila area A_alpla_beta). You will see how it mimicks the continuous/disperse approach... it might not be as simple as a bubble diameter (in terms of 'number' or value) but in effect it is related to it.
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
mixture model or multiphase model in my UDF? aleisia Fluent UDF and Scheme Programming 0 June 8, 2011 13:25
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 10:52
UDF for the mixture model khar nab FLUENT 0 July 31, 2008 06:29
Convergence vs. Length Scale ahlo CFX 3 November 1, 2007 18:20
