Scaling of geometry in CFX-Post
Old   January 9, 2003, 05:53
Default Scaling of geometry in CFX-Post
Mads Bang
Hi, Is there anybody out there who knows how to scale a geometry (say, z direction) in CFX-Post.
Thanks, Mads
Old   January 9, 2003, 06:29
Default Re: Scaling of geometry in CFX-Post
Jesper
Hi Mads. Maybe using the transform command with scale as transforming method will help you. I suppose you are running CFX-5?
Best regards Jesper.
Old   January 9, 2003, 12:20
Swapnil
Hi Mads,
why do you want to scale up the geometry in post? If you want to see the effect of scaling on fluid flow i guess you need to scale up in build so that the fluid flow equitions will be solved for the scaled up geometry. Let me know.
Swapnil
Old   January 9, 2003, 14:19
Jan Rusås
For some presentations it could be nice to scale the results, ie. when the geometry is long compared to the width etc. I have at least also needed the same as Mads.
Old   January 10, 2003, 07:27
Mads Bang
Well, as Jan states, my geometry is wery long compared to the width and height (50:1:2). Therefore it is difficult to post process it. In the old CFX-view it is easy to set scaling factors in all directions.
Best regards, Mads
Old   January 10, 2003, 07:32
Mads Bang
Yes I run the CFX-5-Post. Where do you find the transform command with scale. It's not in my user interface.....I can only see transform-> rotate,translate and mirror.
Best regards, Mads
Old   January 13, 2003, 09:49
cfd guy
Hi Mads,
I'm afraid that you still cannot do it in the 5.5.1 version of POST. The funny part is that the old and limited CFX-VIEW could do this kind of thing. Let's wait and hope that the new version of POST can bring this feature.
Be well, cfd guy
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 17:31
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 15:59
CFX post to Tecplot nandu CFX 2 December 4, 2002 09:27
CFX POST mpeg Revisited henry CFX 2 November 22, 2002 12:42
