January 21, 2003, 10:20 |
CFX 5.5.1 and LES - maximal residuals
Hello everybody !
Is there someone who knows if it is possible to do Large Eddy Simulation in CFX 5.5.1 ? On another subject : how do you know where the maximal residuals are when running a computation in CFX 5.5.1 and the solution oscillates a bit. Thank you very much. Olivier |
January 21, 2003, 14:07 |
Re: CFX 5.5.1 and LES - maximal residuals
Yes it is! Look in the RULES file and talk to your support.
January 22, 2003, 04:29 |
LES: I don't know nothing about that, but i suppose not.
location of max res: at about the end of the .out file there's a section with "Location of max. residuals" (printing out the node No. and the coordinates (xyz)) or you can edit your def/res file and do "add expert parameter section" + "add parameter" + "output eq. residuals" then run some more steps and plot it in post (the residuals will be available as variables) |
January 22, 2003, 04:33 |
Thank you bogezc !
Olivier |
January 22, 2003, 05:43 |
It is possible to do LES with CFX5. I would advice you to do a search in the CFX forum, and you will see a number of responses to that question.
LES in CFX | colen | CFX | 2 | July 5, 2010 09:43 |
CFX 11 Scheme for LES in Multiphase | Man | CFX | 12 | May 25, 2009 20:26 |
LES in Fluent and CFX | taedeneo | Main CFD Forum | 2 | May 6, 2008 13:53 |
LES of Non-Premixed Combustion in CFX?? | Manu | CFX | 5 | February 25, 2008 16:34 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
