CFX5 to tascflow ...
Is there a way to take a CFX5 .res file ( solved with a structured grid ) into Tascflow solver. Please let me know If anyone has done it ? Thanks for your Time. henry. |
Re: CFX5 to tascflow ...
Hi Henry,
Generally the import is in the other direction, thus CFX-5 can directly import CFX-TASCflow grids. Although CFX-TASCflow cannot directly import a CFX-5 grid, you could export the grid to a neutral format, such as a Patran Neutral File, then import this grid into CFX-TASCflow using the Mesh > Import Grid... function on the launcher. Of course, the grid must only comprise of Hex cells, as CFX-TASCflow is a structured solver. The importer will create the block structure as required. Regards, Robin |
Hi Robin,
I want to take the results file inside Tascflow with the results in it, Is it possible by using the emport option in CFX5 to do this. thanks |
No
