February 5, 2003, 06:22 |
Thin surface-BC
Hello! I wont to have two diferent BC on thin surface. On one side I wont to have roughnes=0.0005 an od the other side roughnes=0.00005.Is this posible? How? I work with CFX5.5.
February 5, 2003, 16:20 |
Re: Thin surface-BC
I think it is possible. Create the thin surface in Build as a thin surface with roughness. Then in CCL you will find two surfaces, comprising the thin surface. I think you can change roughness independently although I am not sure as I have never tried it.....
Pascale |
February 6, 2003, 04:58 |
Re: Thin surface-BC
Thanks. It works. In deffinition file I get two surfaces where I can change roughnes.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
