Inflation parameters
I have set an inflation boundary for my geometry, but when I set the inflation parameters and try to write the definition file I get this error message :-
Volume mesh warning: The surface mesh overlaps itself Does anybody have any ideas? Thanks Adrian |
Re: Inflation parameters
Probably a bad IGES file (if you use one) or a too coarse grid, I would say.
It could be that your inflation causes the msh to over lap. eg say we have a 1m^2 duct with an inflation layer of 0.3m on all the walls of the duct, and a global edge length of 0.6m. You may get a problem, as the mesher needs to fit at least one cell between inflation layers. Does your model work without inflation ? Have a look at where the model fails, and look at the geometry in the area. Would the mesh be constricted by the geometry ? bob
