Home > Forums > CFX
Internal sources
Old   March 3, 2003, 06:56
Default Internal sources
Steven
Hi
I am trying to simulate an internal mass source (inlet), by defining an inlet on a solid. However I keep on encountering an error, saying that I have defined a wall between two fluid cells.
Does anyone know what this means ?
Thanks
Old   March 4, 2003, 20:05
Default Re: Internal sources
Robin
Hi Steven,
By internal mass source, do you mean it is surrounded by fluid? Inlets can only be specified on external boundaries.
Robin
Old   March 5, 2003, 05:01
Jan Rusaas
Is it a 3D solid or is it just a wall on a surface. I think it must be a 3D solid.
Old   March 5, 2003, 11:07
Steven
I am using using a 3D solid, to model building column. Attached to this column is a fresh air duct.This fresh air duct is supplied from another floor.
I specified a wall Patch (with a boundary condition ) on a 3D solid column to model the incoming flow.
However I find that I get error messages stating that I have defined a wall between two fluid cells.
Is this the wrong approach ? What is the best way to model this problem ?
Thanks Steven
Old   March 5, 2003, 11:13
Steven
Hi Robin
By internal source I mean I am trying to specify a inlet (wall patch)on a 3D solid within the computational domain.
However I keep on getting an error message stating I have defined a wall between two fluid cells ??
Thanks Steven
Old   March 5, 2003, 18:18
Robin
Did you specify the solid as a cut-out solid in your domains form?
Robin
Old   March 5, 2003, 21:57
Steven
No just one solid
Steven
Thread Tools
Trackbacks are On
Internal boundary problem stefanke OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 May 24, 2011 02:21
Modeling the power sources saisanthoshm88 CFX 2 April 6, 2011 18:46
mapFields : internal edges Gearb0x OpenFOAM Running, Solving & CFD 3 April 19, 2010 09:02
TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 March 30, 2009 15:02
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 02:54
